1967 Frame Sombrero and Receiver Gusset Question - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11326
    Would I be right to assume these gussets and mounts for the differential crossmember got stressed in the past and rewelded? They don't look like normal frame welds to me.
    This body was never off the frame and the differential and crossmember was removed and worked on in the past as I can see.
    I found some John Hinckley photos here and these look normal to me.....
    The frame is out at media blasting now so after it comes back it'll be better to see the welds etc.
    Rich
  • Ray G.
    • May 31, 1986
    • 1189
    Re: 1967 Frame Sombrero and Receiver Gusset Question
    Hello Rich;
    Nice pictures.
    Your pictures show what are typical cracks/breaks I've seen as we disassembled Corvette. Race Corvettes have shown bigger cracks reinforced with the body on the frame.
    Hope that helps.
    Ray
    I hope you dance
    • Bill W.
      • March 1, 1980
      • 2000
      My 65 BB was an old drag racer and had several broken welds on the front cross member area .
      • Tim G.
        • March 1, 1990
        • 1384
        My '67 had one cracked differential mount and one broken ear on the differential cover holding the spring. There wasn't much holding the rear together for all the torque of the big block. Fortunately, bubba welded a traction bar to the cross member and bolted it to the bottom of the spring to reinforce things.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11326
          Thanks guys, my suspicions tell me that also. A common occurrence with that "extra" torque of the big blocks, and in particular this being a 435HP with that additional "capability".
          I may take a ride over to the sandblaster tomorrow and snap a few photos for a better look. I saw him yesterday at a local gas station and he told me he already has half of it done. He has some other large frame related pieces to do too which will take a little more time.
          I have gone ahead and ordered replacement gussets and receivers(sombreros) to be ready for the upcoming repairs to the side rail end caps as well. There's quite a bit of pitting on both gussets and I feel it's time to replace them due to condition as well as the marginal weld repairs.
          Obviously, these repairs were done some time ago with the body on as it's never been off so they couldn't get proper access and I'm unsure of the weld integrity. When the frame comes back to me next week I'll have some more repairs to make. I am very glad we did this chassis over as the further along I got in stripping it down, the more hidden problems I've uncovered.
          Rich
          Link back to original thread....
          https://www.forums.ncrs.org/showthre...866#post730866
          • John S.
            • May 4, 2008
            • 425
            Richard,
            I think you misinterpreted the other answer. I believe (and I am not as knowledgeable as other guys on the DB) that those are original welds. My 65 fuel car had a similar situation on one sombrero and was welded up on the car. Jeff Reade at American Motoring found it and had a welder that he has dealt with for years come over and weld up. For the limited space (Rear end was out of car) he did a wonderful job and I was very pleased with the results.
            John Seeley
            67 Black/Teal
            300 hp 3 speed coupe
            65 Maroon/Black
            35k mile Fuelie coupe
