This has probably been addressed, but I could not find an answer by searching.
I recently purchased a List 3367 which is date correct for my 66. I got it for a very good price, but it has a very nasty areas in the base. It has a lot of JB Weld that someone used to try and fill in what appears to be some pretty heavy pitting. By doing some other research, I found out this is a result of the heat transfer slot in the cast iron intake.
I have read either on this TDB or the Corvette forum about tapping and putting a plug in the slot to prevent this kind of damage. But I also understand that there is supposed to be a stainless steel shim under the carb that prevented this kind of damage.
If the shim protects the base, why not just put the shim back and not mess with plugging the slot? Or am I missing something?
By the way, to the uneducated like me, seeing this damage first hand make it very easy to recognize the damage in pictures of carbs on Ebay and elsewhere.
I've checked Colvin's Chevrolet by the Numbers and he shows the List 3367 being used only on the 66 SB Corvette. Is that correct?
Don
Don
