1969 heater core - NCRS Discussion Boards
1969 heater core
  • Roger G.
    • October 11, 2012
    • 268
    1969 heater core
    Who makes a heater core for a 1969 non AC, that will fit properly and be reliable? thanks
  • Edward B.
    • March 29, 2013
    • 691
    Re: 1969 heater core
    I just got one at Pep Boys for $36.00 a few months ago. Works fine so far.
    Ed
      • 43242
      Roger-------
      If you mean fit EXACTLY as original, the answer is NONE that are currently available. The only exception would be if you could find VERY OLD NOS. The part number won't help you in identifying such a part, though, because the same part number was used from 1968 until September, 1999 but the configuration changed slightly over the years. If you have an original core (likely if "Harrison" is embossed on one of the tanks), you might be able to have re-cored assuming that the current bare cores are the exact same dimensions as originals (which in my opinion is highly unlikely).
      • Roger G.
        • October 11, 2012
        • 268
        Thanks, Looks like a trip to pep boys
