Help Identifying Original 67 Antenna Body - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    Looking for help identifying an original 67 antenna body. Attached are pics of three bodies I have numbered 1,2,3. Two of the three #1 & #2 are identical and have the bowtie symbol cast into the flat area adjacent to one of the tabs. Both of these have the plug in antenna wire. #3 has a bowtie emblem also on the flat adjacent to one of the tabs but has a screw in antenna wire. The separate photo is of an antenna body I came across suggesting it is a correct original 67-68 antenna body. The bowtie emblem is on the curved part of the body 90 degrees from the tabs. Bottom line is #1 & #2 an original or is the body in the separate image correct?
    thanks
    Dereck
