63 temp gauge - NCRS Discussion Boards
63 temp gauge
  • Lawrence S.
    • April 1, 1993
    • 800
    63 temp gauge
    We are struggling with a 63 temp gauge that when the car is stone cold and you turn the key on it reads approx 180*. We have changed out the temp sending unit to what has been described as "calibrated" we have used two different sending units. I am thinking the gauge needs to be calibrated, or is bad. Any ideas?
  • Harry S.
    • July 31, 2002
    • 5293
    Re: 63 temp gauge
    Yes, you can tune them both up. I put my sending unit in a known temperature and hooked up the gauge. Then I moved the needle to that temp.
    I did this several times at different temps to ensure the gauge was correct. Then I put the gauge back in the car.
    • Timothy B.
      • April 30, 1983
      • 5183
      Re: 63 temp gauge
      Harry,
      How hard is it to remove the needle from the gauge, mine also reads high and the sender is a original.
      • Lawrence S.
        • April 1, 1993
        • 800
        Re: 63 temp gauge
        Thank you Harry
          • 15662
          Re: 63 temp gauge
          Check any speedometer repair shop. I've had needles moved on speedometers and tachometers to correct offset error. They can also alter magnetic flux to correct gain error or add gain error to correct for different revs/mile tires that can yield a more accurate speedometer than changing to the next available driven gear.
          The same techniques can be used on any electically driven gage.
          • Rick A.
            • July 31, 2002
            • 2147
            Re: 63 temp gauge
            Tim - check with Rick's Restoration in Joppa - he used to work with Brian Tilles, in fact they are B-i-Ls - send me email and I can give you his contact info at home
            Rick Aleshire
            2016 Ebony C7R Z06 "ROSA"
