Purchased new heater switch from LIC and the switch received requires that I take the wire leads that plug into the switch out of the plug connector that is on wireing harness and use individual connectors that are provided with part. I see other suppliers heater switch listed with individual connectors as well. I don't want to change to individual leads as this was not original as delivered. Are there any alternatives?
66 Heater Switch
Re: 66 Heater Switch
Walter, Russ has the right idea, I myself have taken many switches a part and cleaned the contact surfaces, If the switch housing is aluminum just be careful when straightening the tangs they will break. I use a pencil eraser to clean the contacts and lube the switch contacts after with a small amount of dielectric grease.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
