Mid Year Orange 1956 Corvette Motor? - NCRS Discussion Boards
  • John C.
    • July 11, 2011
    • 122
    Hi,
    Ok, here are the date codes for my 1956 Corvette 225HP motor and a photo for reference.
    3720991 - Block - 5 - 28 - 1956 (E286)
    3731762 - Cylinder Head Left - 5 - 02 - 1956 (E26)
    3731762 - Cylinder Head Right - 5 - 12 - 1956 (E126)
    3731557 - Exhaust Manifold Left - 4 - 30 - 1956 (D306)
    3731558 - Exhaust Manifold Right - 5 - 03 - 1956 (E36)
    The car was found in Hawaii, shipped to CA where the owner removed the engine (he wanted a resto mod) and I bought it complete for my 1956 Chevy Bel Air. I disassembled the engine and found it to be an extremely low mileage motor as there was very little wear and had the original bore of 3.750". The engine had obviously never been out of the car.
    I know, long lead in....but I thought all but the very last Corvette motors of 1956 were Red! My engine is pretty much a May engine and it was orange.....here is a photo of the stock motor mount. I'm not a Corvette guy, so I painted the engine red for my Bel Air....not knowing that Corvette engines were also red for '56....lucky me!
    So, what's up with the mid year orange Corvette motor?
    Thanks!
    John
  • Mark S.
    • July 31, 1983
    • 664
    Re: Mid Year Orange 1956 Corvette Motor?
    John: There have been a few very late 56 Corvettes that have showed up with orange painted engines. My late 56 has some 57 parts on it; and the orange painted engines may have been part of the change over for 57. Sincerely, Mark
    • John C.
      • July 11, 2011
      • 122
      Hi Mark,
      So, would my May engine be considered a candidate for a very late 56 Corvette engine and do they paint the engines as soon as they are assembled?
      Sorry, totally Corvette ignorant!
      Thank You!
      John
      • David B.
        • March 1, 1980
        • 689
        All of engines cast iron components were cast at Chevrolet's central foundry in Saginaw, Michigan and sent to Chevrolet's engine assembly plant in Flint, Michigan for machining and assembly. To answer your question in a shortened version after the engine was assembled, it was painted with a semi-flat paint which covered most of the initial inspection makings. The machined serial pad located in front of the right-hand cylinder head was taped off during painting. Thereafter, they were shipped to St Louis Corvette assembly line as a complete subassembly.
        • Mark S.
          • July 31, 1983
          • 664
          John: To my knowledge, a May car seems a bit early for an orange engine. My Corvette, serial #4200, a late August build, is a car with some 57 parts on it. Sincerely, Mark
          • Dan H.
            • July 31, 1977
            • 1369
            John, just a guess, but it appears the motor mount was painted off the engine, maybe a water pump replacement, then 'detailed' with later chevy orange paint which had to be applied while mount was off engine.
            Dan
            1964 Red FI Coupe, DUNTOV '09
            • John C.
              • July 11, 2011
              • 122
              Ok, thank you David, Mark and Dan!
              Yes, the water pump was replaced and it was obviously incorrect as witnessed by the square hole cut in the motor mount to clearance a top mounted heater hose fitting.
              In any case, it is red now and I'm not going to paint it again.
              BTW, the 2 x 4 carb engine in my avatar was built for my '56 Post and it is not the Corvette engine.
              Thanks again!
              John
              • Gary C.
                Administrator
                • October 1, 1982
                • 17771
                John,
                Does your engine have a production date with engine application suffix and a manufacturing sequence number stamped on the pad?
                Late 1956 4206 engine was 1956 red. The last 100 1956's and 1st 100 1957's give or take a few were produce at the same time in St. Louis.
                4206 has a mid June date frame stamp and a 1957 frame stencil 303190-40. 4206 was produced Augst 16, 1956.
                4206 lead me to discover that August produced 1956's has the 1957 1st design frame 303190-40
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • John C.
                  • July 11, 2011
                  • 122
                  Hi Gary,
                  Ok......here you go:
                  Thanks!
                  John
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17771
                    John, 1956 engine stamp pad information that's close to your engine stamp pad that was collected by the late Mike Hunt. Gary....
                    Engine Sequence No. 1956 VIN Transmission Block Cast Date
                    0506966F56FG E56S002947 Automatic
                    0505217F56FG E56S002943 Automatic
                    0505122F56FG E56S003023 Automatic
                    0550918F56GV E56S003222 3 Speed F216
                    0505118F56FG E56S003591 Automatic
                    NCRS Texas Chapter
                    • John C.
                      • July 11, 2011
                      • 122
                      Hi Gary,
                      So, the ascending vin number indicates a later car mfg date, an ascending engine sequence number indicates a later engine mfg date, but the two together can and often are out of sequence, correct?
                      Thank you!
                      John
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17771
                        John,
                        Parts including engines came into St. Louis and basically were used without respect to any sequence, engine number, etc.
                        Gary
                        NCRS Texas Chapter
                        • John C.
                          • July 11, 2011
                          • 122
                          HI Gary,
                          Ok, thank you!
                          Btw, what is the secret to formatting a reply as it relates to table alignment?
                          I finally had to give up after numerous attempts.......I simply could not duplicate your table as I wanted it!
                          John
                          • Joe R.
                            • May 31, 2006
                            • 1822
                            Hi John,
                            I had the same problem with aligning text in a table. I think I finally resorted to a table in Word, saved as a PDF. Maybe I printed and scanned, I don't remember. A lot of trouble, I remember that much!
                            Joe
                            • John C.
                              • July 11, 2011
                              • 122
                              Hi Joe,
                              Ok, I will try experimenting with word, pdf's etc.
                              Thank you.
                              John
