Washer hose size - NCRS Discussion Boards
Washer hose size
  • Doug W.
    • October 27, 2011
    • 43
    Washer hose size
    Did the windshield washer pump have two different size hose ports in 1965? I ordered a hose kit from a popular repro company and I received all four hoses with same size ID and OD. My pump has a one larger intake port and two smaller discharge ports. Which is wrong, the hoses or the pump? Thanks for your help.
    • 6955
    Re: Washer hose size
    Doug, the repro hoses are not correct, as you noticed they are a different dia. the repro hoses will still work.if the old hoses to the nozzles are still useable I would reuse. generally the get hard and break though try using a blow dryer or heat gun to soften before you re-install. and the nipples with some dielectric grease.
    • Larry M.
      • January 1, 1992
      • 2701
        • 43273
        Originally posted by Larry Mulder (20401)
        Although he has a reputation of being difficult at times, DR REBUILD rubber products are generally second to none………both in fit and finish. For "soft goods" for my car, I almost always buy from the doc.
        Larry
        Larry------
        Yup!
        • Doug W.
          • October 27, 2011
          • 43
          Lesson learned! Thanks again to all for sharing your knowledge.
