Somehow I don't think I'm going to like the answer to this inquiry. In the process of restoring my '65 telescopic steering column on the bench, I replaced the lower felt, upper bearing, directional switch, and harness. I didn't replace the lower bearing because frankly I couldn't get it out without breaking something, and it otherwise appeared intact. I cleaned, re-lubed, and painted everything. And I "think" I put everything back together correctly (but maybe I missed something.)
I was pleased that the directional signal and horn worked as I was approaching completion, and the steering wheel turned with no slop. But upon attaching the "star" tele screw (the multi-pronged screw head that screws into the shaft right under the horn button retaining piece), I found that the telescopic wheel won't lock down tight. In other words, even when I tighten the screw, the telescopic upper jacket will continue to slide up and down--it won't "lock down" to prevent it from continuing to slide backwards and forwards. I followed the Assembly Manual instructions in reassembling (or at least I think I did.) I will note that the aforementioned star screw seemed a little tight when I first started screwing it in, and then when it neared its "bottom out" position, it was a lot looser for 2 or 3 turns (for whatever that's worth).
I researched the Archives here with no luck. And Jim Shea's articles seemed to apply to newer vehicles.) I also researched the "other forum," where I finally found one rather cryptic response suggesting that either the upper bearing is broken or I need to turn the inner column (or shaft or something?) 180 degrees. I "think" the upper bearing is not broken, so that leaves the "180 degree" fix, or whatever else you guys come up with (which hopefully would be less intrusive than removing the column from the car and taking everything back apart). In any event, if I need to turn something 180 degrees, can someone please explain what exactly that entails? Thanks as always in advance for whatever assistance you can provide.
Mike H.
Mike H.
