correct location for wheel weights on a 1991... - NCRS Discussion Boards
+ More Options
Posts
  • Kevin N.
    • September 30, 2002
    • 88
    I previously posted a question for the correct type of wheel weights used on a 1991 and got the answer. I just did an archive search on the correct location of said wheel weights and found nothing. my question is...should the wheel weights be installed on the outer side of the rim or the inner side of the rim like older corvettes do? thanks in advance.
    in garage now...1991 Z07 coupe... ex-garagers...64cp, 65cvt, 66cvt, 66cvt, 66cp, 66B.B.cp, 67cp, 67cp, 67cp, 69B.B.cp, 69cp, 69cp, 69cp, 70cp, 70cp, 70cvt, 71cp, 71LT1cp, 72cp, 72LT1cp, 72cvt, 73L82cp, 73cp, 73L82cp, 74L82cvt, 74cp, 78s.a.cp, 79cp, 84cp, 85cp(twice), 88cp, 89cvt, 91cvt, 96cp, 96LT4cp, 98cvt, 99frc, 00frc, 00cp, 01cvt, 04cvt, 04Z06
    • 11698
    Re: correct location for wheel weights on a 1991...
    Here you go
    https://www.forums.ncrs.org/showthre...-wheel-weights
    • Kevin N.
      • 88
      Patrick, that's my old post that only says what kind of weights to use. I did, however, see the post that shows pics of the location on a 95. I will just go with that and see what the judges say. thanks.
      • David K.
        • September 30, 1979
        • 244
        The auto tech that balances the tires will put the weights on the wheel. You just must make sure they use the correct type of weight.
          • 43297
          Kevin-----
          I believe the weights were installed on both sides of the rim. However, I can tell you, for sure, that some were installed on the outside of the rim.
          • Ed N.
            • May 16, 2010
            • 1003
            I have had my 1995 C4 judged up to a Hill Award and the placement of wheel weights has never been an issue. In fact, the wheel weights themselves has never been deducted and I have on some occasions used the adhesive weights placed on the inside of the wheel. Just my real life experience.
            Ed Nieves
            NCRS #51799
