1961 Front License Plate AIM Documentation - NCRS Discussion Boards
  • John G.
    • September 24, 2013
    • 245
    Two other C1 guys stopped over yesterday and some attention went to my front plate. I tried to find the documentation for the correct bolts for the back plate and the lower bar. At least in my paper AIM pages A169/A170 don't show these parts nor the fasteners. Where is the documentation for this? Is this lower bar installed correctly?
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 1961 Front License Plate AIM Documentation
    I don't know about the bolts but do you have a full front-on shot of your license plate holder ?
    Something doesn't look right but can't say 100% from that pic...
    Can you fit more than a fingertip between the top of the license plate bumperette and the horizontal center bar ?
    • John F.
      • March 23, 2008
      • 2414
      Section 12 Sheet 11.00
      • John G.
        • 245
        This is a shot from below and then one just about straight on. I took my MN collector plate off per advice since the car didn't come with one.61-f-l-p-2.jpg61-f-l-p-3.jpg
        These are more pictures. I can put only the first joint of a finger through - it's about 7/16" clearance.
        • Frank D.
          • December 27, 2007
          • 2703
          That's fine John. For a minute I thought you might have had the earlier C1 brackets for the license frame. They drop it several inches from stock on '61/'62 cars. Common mistake but yours look correct.
          • John G.
            • 245
            Thanks Frank. If you're at Sun 'n Fun I look forward to meeting you.
