Can't Remove the Trailing Arm Bolt - NCRS Discussion Boards
  • Bob P.
    • June 30, 1998
    • 143
    I'm doing a body off on my '71 LT1 and I have everything removed from the chassis and I'm down to the last 2 bolts, which are the front trailing arm bolts that go through the frame. I have used every type of rust penetrating fluid, I have used a torch, I have actual even burned all the rubber out of the bushing in the front of the trailing arm and still can't get the bolt to come out. I can however rotate the bolt. Should I cut the bolt? I'm half afraid to do that because I still won't be able to get the thing out unless I can push the bolt out of the hole. Any suggestions?
    Bob Puls, 30633
  • Mike E.
    • June 24, 2012
    • 920
    Re: Can't Remove the Trailing Arm Bolt
    Bob,
    I had to take a sawzall to mine to get them out. Cut the bolt on both sides of the bushing through the pocket in the frame. Like you I tried everything, had them out in about 10 minutes with the sawzall technic.
    Mike
    • Rich C.
      • January 1, 1994
      • 383
      Bob,
      Just had to remove mine last year, used a sawzall with blades called "the torch", think they were Milwaukee brand. My sawzall is a variable speed which gives you much better control. Still used 4 blades to take care of both sides. Wear gloves!!!
      1973 LS-4 454 coupe owned 24 years
      1996 LT-4 CE coupe
      Sierra Nevada Celebration Ale currently on tap (update-just kicked')
      • David H.
        • June 30, 2001
        • 1571
        Bob,
        Sawzall. You may want to jam the bolt so it cannot rotate. Be sure to note the quantity, sizes and location of the shims BEFORE you remove them.
