Should I paint the '61 mufflers for judging - NCRS Discussion Boards
  • John G.
    • September 24, 2013
    • 245
    With NCRS judging points as the primary consideration should I high temp paint the mufflers on my '61 or leave as they are? If I should paint them what's a readily available recommended paint?
  • Art B.
    • 333
    Re: Should I paint the '61 mufflers for judging
    The 1961-62 Judging Guide on page 86 states: "Mufflers and pipes were painted black (do not deduct if paint is burned off)." I guess it is your call. If it were me, I would use a high heat semi gloss or flat paint.
    • John G.
      • 245
      Thanks. I have a guide. Was wondering if this would get more points leaving them as is - off to the store to buy high temp black and get spraying.
      • Jerry K.
        • December 1, 1981
        • 93
        Be sure to place newspaper behind the mufflers and pipes so no paint gets on the underside of the body. I see by the picture that your shocks are red, I would peel of the Delco sticker and shoot some Kylon semi gloss paint on them as well.
          • 11668
          If the mufflers are replacement you will often lose on configuration and finish issues already, so the black paint becomes a non-issue with regard to points. However, most of us paint them anyway.
