I've looked at the AIM for my 72 and i need a gas line clip that hold the rubber gas line from tank to rear frame. I see a #125921. Other clips on frame have #3923695 and are smaller. And wont fit the gas hose. What size is the 125921 clip. Havent been able to find one.
					fuel line clip size difference C3
Re: fuel line clip size difference C3
Ken, the 125921 clip was a #10-5/8" with a 5/16" bolt hole and was used for 5/8" hoses. Discontinued MANY years ago with no replacement shown.
EdAttached Files- Top
Ken, it doesn't appear it's being reproduced, but if you're not having your car judged, you might be able to get something that will work at your local auto parts store. Or, if that doesn't work, AMK sells clips as well, but I think you have to place a $50 minimum.
The AMK part number that's the closest to what you need appears to be B-10268. It has a rubberized coating, but again, if you're not getting the car judged, I would leave it on. And HERE'S the link to their catalog. (click on pages 138-150 and it's down toward the bottom)
Ed- Top
