Clunking noise when putting PG into gear - NCRS Discussion Boards
    • 15706
    Re: Clunking noise when putting PG into gear
    Originally posted by Russ Steinhaus (5540)
    Duke, Why is the Chevrolet spec for idle so high then? 700 RPM in drive which is about 900 in neutral or park?
    Were do you get 700? The '67 AMA specs say 500 in Drive unless it has K-19, which is 600. (Emission controlled engines always have higher idle speed recommendations because it will lower emissions.)
    IMO a lot of recommended idle speeds are a joke. Try to get a Duntov cam to idle at 700!
    If you go back a few years idle in Drive with PG was specified as low as 450.
    My advise for idle speed: "The lowest possible commensurate with acceptable idle quality". So it will vary with engine configuration and what various owners consider "acceptable".
    No rush on the speed/vacuum data, but I would like to get it.
