365 HP pulley, what belt width? - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    What belt width did the 365HP have? A 3L = 3/8", a 4L=1/2". 1/8 " for number. 5L would be a 5/8" belt.
    Dom
    • 43290
    Re: 365 HP pulley, what belt width?
    Dom
    Dom------
    All 1965 L-76 belts were 3/8" width. No 5/8" width V-belt was EVER used on ANY Corvette.
    • Domenic T.
      • January 29, 2010
      • 2452
      Got some 4L on my BB from LICORVETTE for the AC. Did any of the others use a 1/2" on the AC? Did the 365 HP use a 1/2" on their AC?
      Dom
        • 43290
        Dom
        Dom-----
        No 1/2" V-belts were used on Corvettes, either. However, the A/C compressor belt was often 15/32", including for the 1965 L-76 with C-60 application.
        • Wayne M.
          • March 1, 1980
          • 6414
          ...... Did the 365 HP use a 1/2" on their AC? ....
          Dom --- not from what the AIM and P&A30 parts catalogs say. The AIM (UPC C60, Sheet C2) shows # 3849085, which was revised from 3847705 on Jan 19th 1965. My P&A30, Rev May 1st 1965 lists 3847705 as a belt of 57_1/2 inch length and 15/32" wide, for all '64-'65 Corvettes with C.A.C. [I guess not for just the big pulley compressor ].
          Mind you, 15/32 is darn close to 1/2".
          P.S. Oops, looks like Joe already responded to the exception. Wonder if Joe knows what size the 3847705 is ?
          • Domenic T.
            • January 29, 2010
            • 2452
            Wayne,
            So if I understand you correctly the big 6 3/8 pulley could have a 15/32 belt?
            DOM
              • 15706
              OE accessory drive belt dimension data are in the AMA specs.
                • 43290
                [QUOTE=Wayne Midkiff (3437);
                Wonder if Joe knows what size the 3847705 is ?[/QUOTE]
                Wayne------
                15/32" X 57-1/2"
