69 l71 things to look for - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 825
    A friend is looking at what is supposed to be a decked 69 L71 . Are there telltale signs to look for on a big block or 435 car?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11356
    Re: 69 l71 things to look for
    Bob What do you mean by telltale signs? Do you mean how to tell if it was originally a big block car, or in fact a BB 435 car?
    I'm familiar a bit with the '67 L71's but not the '68/'69.
    Rich
    • Bob H.
      • July 31, 2000
      • 825
      Rich
      I am familar with the 67 but have no knowledge on c3's, specifically the 69. Any information to help confirm its original the possible identity would be helpful when looking at the car. It's unknown right now if there is a tank sticker. The car is not restored. I'm assuming the rear should have the same style setup as the 67 but that's all I know to look for.
      bob
      • John C.
        • January 1, 2005
        • 616
        Bob
        You want to look for are pretty much the same things on a 69 as a 67 to tell if it was originally a 427 car.
        Things to check for on a 1969 L71 car:
        -6500 red line tach
        -Transistor ignition
        -Single fuel line
        -HD rear end and axle caps
        -Copper radiator
        -Close ratio transmission if it is a manual
        -BB cars had a 15/16 inch front and 9/16 inch rear sway bars
        -F41 HD suspension was available as an option on L71 cars
        -A/C not allowed as an option
        John
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11356
          John,
          Did the back of the instrument clusters on the C3's have a unique identifying label for the hi-rpm tach, like on the '67's?
          1967 LB
            • 15625
            John,
            1967 LB
            [ATTACH=CONFIG]57159[/ATTACH][ATTACH=CONFIG]57160[/ATTACH]
            Yes they do Richard.
            • Bob H.
              • July 31, 2000
              • 825
              Thanks guys. That's enough to go on. Didn't realize how similar to the 67 Bob
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11356
                Thanks Terry
                Me neither, now we know. It would certainly be more difficult to see those labels behind the C3 clusters though.
                  • 15625
                  Thanks Terry
                  Some diss-assembly required.
                  • Bob H.
                    • July 31, 2000
                    • 825
                    can someone tell me the location of the TI box?
                      • 43263
                      Bob------
                      It's on the forward side of the driver side front fender well, to the left of the radiator support.
                      • Bob H.
                        • July 31, 2000
                        • 825
                        thanks Joe
