Castle Nut 3774712 - NCRS Discussion Boards
Castle Nut 3774712
  • Bill L.
    • February 1, 2004
    • 1403
    Castle Nut 3774712
    The nut is used in two places. Trailing arm bolts and Differential mounting bracket.
    Could they originally have been two different finishes, natural and/or zinc?
    Thanks, Bill
    • 43287
    Re: Castle Nut 3774712
    Thanks, Bill
    Bill------
    The vast majority of slotted nuts used on Corvettes were plain (i.e. natural) finish. However, the 3774712 was an exception. It was zinc plated. However, there were actually two finishes. The older examples were ordinary zinc plated. Later examples were zinc plated with a chromate (i.e. "goldish") overplate. When did the change occur? That I don't know.
    By the way, no castle nuts were used on 1963-82 Corvettes; only slotted nuts were used. Castle nuts and slotted nuts have a different configuration.
    • Bill L.
      • February 1, 2004
      • 1403
      Bill------
      Thanks Joe.
      I think the nuts on the lower shock mount to spindle support were zinc too.
      I remember you mentioning the difference between castle and slotted nuts before.
      Thank you for all your help and Happy New Year!
      Bill
        • 43287
        Thanks Joe.
        Bill
        Bill------
        Yes, the shock mount slotted nut was the only other slotted nut used on the suspension of 63-82 Corvettes which was plated (zinc). All others (except the 3774712) were "plain" finish.
        By the way, be very careful when purchasing replacement slotted nuts for Corvette suspension. Most slotted nuts originally used were GM-300-M (SAE grade 8) while a few were GM 280-M (SAE grade 5). However, most of the slotted nuts on the market today are zinc plated and of SAE grade 2 or UNGRADED. Not suitable for suspensions with critical safety-related implications.
        • Bill L.
          • February 1, 2004
          • 1403
          Bill------
          Thank Joe,
          That makes it easy to remember.
          Bill
