67' lower A arm shaft orientation; up/down - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    Is there a right side up and right side down for the lower a arm shaft? I see there is a serial number just before the two winged holes on the shaft. Should it be facing up toward the engine or down toward the ground?....or doesn't it matter?
    Dave
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 67' lower A arm shaft orientation; up/down
    Yes the pad that has two bolts is flat on the top side. That side sets flat when bolted.
