I have been trying to get this carburetor running right and I've got the driveability issues solved but it continues to dribble a very small about of fuel from the primary transfer slots down into the intake, and some of the fuel seeps out around the throttle plates when the engine is shut down. And of course, when you restart it when hot it takes a few seconds of cranking because there is so much fuel in the intake.
The car is a "66 350HP coupe with A.I.R. (fully functional) - the carb is a correct list 3605 with a 4920 metering plate. The float levels are correct, the power valve is a 6.5 and has been replaced to isolate that as a cause.
What I don't understand is what would cause fuel to seep out from the transfer slots?
I just rebuilt a friends' list 3367 carb off his "66 300HP engine and when I dialed it in on my car it runs perfectly - no leaks or seepage, and the engine starts immediately when either hot or cold.
Any suggestions?
Bob
Any suggestions?
Bob
