72 thru 75 shock absorber part numbers - NCRS Discussion Boards
  • Kent B.
    Infrequent User
    • April 1, 1978
    • 2
    Could members with access to factory assembly manuals for 72 thru 75 list the shock part numbers shown for both base & uplevel rpo's.
  • Roy V.
    • April 8, 2008
    • 311
    Re: 72 thru 75 shock absorber part numbers
    Kent, you've been a long time member, I see this is your first post on the TDB, Welcome.
    my assembly manual just covers the 1972 model year and gives two part numbers for the fronts and one for the rear.
    on page M157 sheet A4, for the front shocks
    part #4949705
    part #4949806 with rpo F41
    on page M162 sheet A3, for the rear shocks
    part #4949820
    hope this helps some and I'm sure others will be by soon to fill you in on the other years you asked about.
    regards
    Roy
    1972 LT-1 Elkhart Green Coupe
      • 43273
      Kent------
      1972
      standard suspension: front---GM #4949705; rear----GM#4949820
      F-41: front---GM #4949806; rear---not specified
      1973
      standard suspension: front---GM #4975167; rear---GM #4975168
      1974
      standard suspension: front---GM #4975167; rear----GM #4975168
      Z-07: front: not specified; rear---GM #4940607
      1975
      standard suspension: front---GM #4984666; rear---GM #4984667
      FE-7: front---not specified; rear---GM #4984803
      • Kent B.
        Infrequent User
        • April 1, 1978
        • 2
        Thank You for the quick responses!
