Aluminum differential carrier bolt torque? - NCRS Discussion Boards
  • Kenn S.
    • September 10, 2009
    • 173
    Anyone know the torque specs for bolting the differential case onto the carrier for an aluminum carrier (1980 - 1982)?
    I've looked in the AIM, and it assumes the differential assembly is complete, so no specs there. The shop manual gives me all kinds of torque settings, but unless I misread or misunderstood the language, I don't see specs for bolting the carrier to the case.
    I don't want to over-torque it, since it's aluminum, and under-torque would seem to be a problem as well.
    -Kenn
    1970 LS-5
    1970 350/300
    1980 L-48
    2004 LS-1
  • David H.
    • June 30, 2001
    • 1526
    Re: Aluminum differential carrier bolt torque?
    Kenn,
    I don't have a direct answer to your question, however, I believe the 1980-82 Dana 44 is similar to the C4 Dana 44. The attached image is from the 1996 shop manual and shows bolt sequence and torque values. This may be a starting point, but I would wait for someone that actually knows what they are doing to respond.
    Dave
    • Kenn S.
      • 173
      You're correct, it is a Dana 44. I would have over-torqued them...was thinking 45Nm in a star sequence with no other guidance. I'm pasting this into my shop manual.
      Thank you!
      -Kenn
      1970 LS-5
      1970 350/300
      1980 L-48
      2004 LS-1
      • David H.
        • June 30, 2001
        • 1526
        Kenn,
        While I think these torque values are in the ball park, you may want to wait until a knowledgeable me member responds.
        Dave
          • 43221
          Originally posted by David Houlihan (36425)
          Kenn,
          Dave
          [ATTACH=CONFIG]56894[/ATTACH]
          David------
          The difficulty in making this comparison is that the bolts used for the 80-82 Dana 44 cover were different than the bolts used for the 84-96 Dana 44 cover. The 80-82 bolts were GM #14024363; the 84-96 were GM #14091419. It's possible, of course, that the torque for both bolts was the same but the fact that different bolts were used makes me wonder.
