66 Front lower shock bolts - NCRS Discussion Boards
  • Brian K.
    • May 31, 2004
    • 358
    Did the original front lower shock absorber mounting bolts have a serrated washer on the 66 model year? If anyone has a picture of an original it would be much appreciated. Sincerely Brian
    • 6942
    Re: 66 Front lower shock bolts
    Brian, does the 66 JM have any details? I know that my 63 has serrated washers on the lower mounts, I think that 63/64 maybe the only years, I believe that the most have the lower shock bolts with the fixed washers, just about the same as the hood hinge bolts, maybe a tad longer though. I read my 63/64 JM and its funny that it does not even mention serrated washers. Although I believe that's a era.
    • Anthony P.
      • October 26, 2011
      • 199
      My 66 JM states "The lower attachment bolts are black phosphate recessed hex-head bolts with loose washers" no reference to serrated washers. Hope this will help you!
      • Brian K.
        • May 31, 2004
        • 358
        Thanks guys. I had checked the JM and read the description, but still not sure plus we all no the JM is not perfect on everything. I would like to see an known original example for headmarkings and what the washer looks like.Sincerely Brian
        • Rich P.
          • January 12, 2009
          • 1361
          Brian, 63-mid 64 used the serrated washer bolts after that all were non serrated. Rich.
          • Rich P.
            • January 12, 2009
            • 1361
            Also know headmarkings I have seen on 66's are C, Anchor, RBW, E and at least 3 more. Rich.
            • Brian K.
              • May 31, 2004
              • 358
              Thanks Rich that's the info I needed. Sincerely Brian
              • Jim S.
                • March 1, 1986
                • 1398
                Brain ,
                Here are pics of what was on my 66. Hope they help.
                Jim
                  Those are commonly referred to as "captured free-spinning conical washers".
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    The design department (years ago) I was at used the trade term "SEMS". I think that was just one of the vendor trade names as I recall.
                    The shank just under the hex head, where the washer is, is just under the minor diameter of the thread making these screws a less torque yield when tightening. So use care not to over stress and snap the heads off.
                    • Brian K.
                      • May 31, 2004
                      • 358
                      Thanks for the photo's and input guys. Sincerely Brian
                      • Kenneth F.
                        • September 30, 1988
                        • 282
                        Brian, I have a mostly untouched 1966, owned since 1967. The shock, lower bolts have a recessed head, with a plain flat washer that stays with the bolt, someone mentioned captured washer. The end of the bolt comes to a point, and the head is marked with a C, with 3 lines going through the letter.
                        • Gerald C.
                          • June 30, 1987
                          • 1283
                          Ed,
                          I have the serrated bolts for my front shock bolts. Are the ends flat to do they come to a point as I have two choices of bolts.
                            • 6942
                            Originally posted by Gerald Coia (11656)
                            Ed,
                            Jerry serrated washers with pointed ends are correct for 63 shock lower mountings, if you still have them that’s great, 63 has serrated washers in a few locations. If you need more info on locations let me know.
                            • Gerald C.
                              • June 30, 1987
                              • 1283
                              Thanks Ed. But are the ends pointed or flat?
                              Jerry
