C2 clock coil - NCRS Discussion Boards
C2 clock coil
  • Patrick B.
    • August 31, 1985
    • 2003
    C2 clock coil
    I have a 67 clock with a burned out coil. Is there a source for replacement parts? What would cause the coil to burn out?
  • Frank D.
    • December 27, 2007
    • 2703
    Re: C2 clock coil
    These guys will do it for you for $30....maybe they'll sell you the coil:
    The Clock Works is your full-time automotive clock service center! With over 30,000 units serviced, we are the first choice for vintage and collector car clock sales and service. No radios, no gauges, no speedometers, no tachometers... Just clocks done right!
    • Mike E.
      • June 24, 2012
      • 920
      Re: C2 clock coil
      The points sticking when the coil is energized. It seems like if you use a really cheap battery charger that does not output clean DC and have the cables connected while charging it can cause issues.
      Mike
        • 6950
        Re: C2 clock coil
        Pat, I believe if the battery goes low or dead this will cause the clock to cycle many times and fuse the points which overheats the circuit.
        • Patrick B.
          • August 31, 1985
          • 2003
          Re: C2 clock coil
          Thanks for the information. It sounds like burned out coils may be a common problem. I wonder if the coils are unique to Corvettes or common to most GM cars of the era?
          • Larry M.
            • January 1, 1992
            • 2701
            Re: C2 clock coil
            Pat:
            I am almost certain that the coils were common to most models. The clock sizes and faces were obviously different.
            Rebuilding should not be an issue. Frank gave you the place.
            Larry
