I am assembling the z bar and clutch fork levers and things just don't feel right.....the clutch fork has the spring clip over the ball stud, but it appears sprung, and loose....I have never assembled a 62 fork and clutch. If I depress the z bar it seats and depresses the fingers, but if I don't lift up on the arm it will bind......is the easy answer to replace the fork, or am I missing something , I need to finish this before putting on the exhaust....your help and ideas would be appreciated. Dino
1962 clutch fork wobble
Re: 1962 clutch fork wobble
John Hinckley replied to the similar thread you posted about this on the CF.
It appears the fork is not positioned correctly so the spring clip hasn't "captured" the ball; make sure you have the right fork !!
C1 & C2 Corvettes - 1962 clutch fork problem - I am in the process of assembling a frame off restoration with all factory components.....something doesn't feel right and I would like your opinion....the fork has the spring clip that holds the fork in the bell housing stud is loose, should it be tight? The fork has a...- Top
