Bench Top Check of Power Window Motor - NCRS Discussion Boards
  • Bob P.
    • June 30, 1998
    • 143
    I have removed the power window motors out of the C3 that I'm restoring. The car hasn't ran for 20 plus years and I wanted to do a bench top check on the motors to see if they were still operational. Any suggestions on how I can power up the motors?
    If they are bad, is there anyone who restores these motors? Thanks
    Bob Puls, 30633
    • 6959
    Re: Bench Top Check of Power Window Motor
    Bob, should be very easy to check, Use the case as ground and jumper out each terminal, Motor will run in each direction as you power up the terminals.
