corvette 1965 engine number stamp help - NCRS Discussion Boards
  • Keith W.
    • June 30, 1998
    • 375
    I've brought a 65 its about 6 days away from docking in the UK I have all the info of the 65 except the engine number
    So the vin is 194375s103737 it a 300 AC code HR
    So engine stamp will be 5103737 XXXXXHR
    I need the rest of the engine number for the customs and duty / government, yes I should have taken note when I checked the vette over - my bad
    All help as always would be good thanks Keith
  • Mike M.
    • May 31, 1974
    • 8400
    Re: corvette 1965 engine number stamp help
    the alpha numerics u seek are unique to the engine in your 65, hence none of us can supply them. you will have to wait till the ship docks to get the info. mike
    • Dino L.
      • February 1, 1996
      • 694
      You can guess.... it should read F0915HR through F1015HR would be my guess.....FMMDDHR
      Dino Lanno
      • Mike M.
        • May 31, 1974
        • 8400
        doubt customs officials would accept a guesstimate. mike
        • Keith W.
          • June 30, 1998
          • 375
          Thanks i'll take the f1015hr they don't check the engines but at some time it has to go on our pink slips if its slightly different I can cover it off then - thanks again guys as always really helpful
          Have a good Xmas guys and new year all the best Keith
          • Robert G.
            • May 31, 1990
            • 429
            This web site says F1117HR
            Nov 2, 2014 ... 1965 Chevy Corvette Sting Ray Coupe 327/PowerGlide. Serial Number
            194375S103737 Engine Pad 5103737 FIII7HR Trim Tag 450A A-552 ...
            • Keith W.
              • June 30, 1998
              • 375
              Robert just been on the web link excellent bit of detective works thanks again Keith
              • Michael W.
                • April 1, 1997
                • 4290
                In case you're curious, the F1111HR decodes as an engine assembled at the Flint engine plant on November 11th. Rather significant date.
                • Jimmy B.
                  • July 31, 1980
                  • 584
                  when I brought my 67 CORVETTE into the country a few years ago they did not care about the engine number, the VIN is what they did care about. If you are on a base the base vehicle registration can help you with all the forms. also I had to hire an "agent" for me once it arrived in port, I have a connection possibly if you haven't arranged this already. It should all be done prior to your car being shipped over. What dock are you using. I imported 5 cars while i was there. You can bring it over duty free if you have a SOFA stamp in your passport like I did. Good luck with it over there. My 65 also is an auto with ac and has a HR code on the pad like yours.
                  • Keith W.
                    • June 30, 1998
                    • 375
                    Jimmy am a UK resident so I have to pay the tax - Vettes coming into Tilbury London - vin info is fine as I have a copy of the pink slip it was the request of the engine pad that threw me - that's all sorted now - the UK registration document which is your pink slip also has the engine pad details on this is to reduce and control theft of a vehicle also cut and shunt , which is where they put two damaged cars together to make one. Thanks again Kerith
                    • James G.
                      • May 31, 1976
                      • 1556
                      Keith, the car is still posted on CORVETTE FORUM. Serial Number 194375S103737
                      Trim Tag 450A A-552 F-F
                      It was built December 4, 1964.
                      There is also a photo of the engine pad. SEE THE ADD HERE AND COPY THE PHOTO.
                      http://www.corvetteforum.com/forums/...ocal-area.html
                      I know the car and history. You found a good one for very reasonable money.
