66 - brake calipers - NCRS Discussion Boards
66 - brake calipers
  • Stephen L.
    • August 29, 2007
    • 205
    66 - brake calipers
    hi guys - i was not paying attention when i took my calipers off and now see one bolt is 1 inch and the other is 1.25 inch - i am now putting the calipers back on - which hole takes the longer bolt? - thanks
    • 43273
    Re: 66 - brake calipers
    Stephen------
    If you're referring to the bolts that retain the calipers to their brackets, the 1-1/4" bolts are used for the front calipers and the 1" bolts for the rear calipers.
    • Stephen L.
      • August 29, 2007
      • 205
      Exactly what I was referring to - thanks Joe
      • Stephen L.
        • August 29, 2007
        • 205
        Joe/anyone - as a follow on, i am rebuilding the master brake cylinder (66, manual single pot) and the kit has no instructions - makes sense since there are only 4 pieces - yet, i can't remember if the black cup goes onto the spring such that the end of the spring sits inside the cup or the other way around - does anyone know?
        thanks!
          • 43273
          thanks!
          Stephen------
          The spring mounts inside the cupped side of the seal.
          • Russ S.
            • April 30, 1982
            • 2163
            If you have a smart phone, take pictures as you disassemble.
            thanks!
            • Stephen L.
              • August 29, 2007
              • 205
              Thanks Joe
              that is the way i happened to do it...but after bleeding the system i cannot get a firm pedal
              i thought maybe it was supposed to go the other way
              is there a stop on the brake pedal other than the floor? - mine does not have one...my only other thought is that i pushed the plunger in too far and broke a seal?
              because other than that, i seem to be good - i am using a mighty vac (mini) and am getting clear fluid no bubbles, closing bleeder under vacuum and on to the next one...all are good
              no visible leaks....frustrating - but the brake pedal has not very much resistance and travels all the way to the floor....??
                • 43273
                Thanks Joe
                Stephen------
                There is no lower stop for the brake pedal other than the floor.
                You should bleed the master cylinder OFF the car.
