TI amplifier finish - NCRS Discussion Boards
TI amplifier finish
+ More Options
Posts
  • Robert M.
    • April 30, 1999
    • 415
    TI amplifier finish
    My 67 original TI amplifier needs refinished. Were they originally gloss or flat black? Thanks
  • Ken A.
    • July 31, 1986
    • 929
    Re: TI amplifier finish
    Gloss black
    • Donald A.
      • March 1, 1987
      • 243
      The '67 Judging Guide just states that amplifiers are painted black, doesn't clarify gloss-semi-flat etc. The original TI amps that I have seen have all been gloss black, including the one in my car.
        • 15621
        Isn't the base plated gold color?
        • Donald A.
          • March 1, 1987
          • 243
          Yes, my reply referenced the housing only (black) not the base plate which is a separate piece. Thanks, I should have clarified that.
          • Robert M.
            • April 30, 1999
            • 415
            Thanks all for refreshing my old memory. I will pull mine and refinish it in gloss black. The electonics ae all freshly redone.
            • Mike Z.
              • 226
              The amp housing was painted semi-gloss black (slightly glossier than the distributors, but not nearly as glossy as we know gloss to be today), then the mounting hole was machined the size of a flat washer at the three mounting ears (this is necessary to insure a good ground, so if you are not planning on re-machining; place a flat washer centered over the holes as a mask). The backing plate was dychromate (not gold painted), as were the attaching screws. The Delco decal was applied up-side down (as seen when the housing is mounted)-I have to assume so it could be read more easily when the unit was installed.
              We recommend media blasting all the brass terminals to insure the best connection possible and a little dyelectric grease in the terminal boot. Also, media blast the inside of the housing to insure your new module has a sufficient ground.
              Restoring these amps is one of our specialties and do many per year; so, information is from GM blue prints and experience of seeing hundreds of original amps.
              Mike
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11345
                Mike I've seen your restorations of the TI items and you do outstanding work.
                I played around a little bit with my first TI box a few years ago. It was on a early '67. I used a semi-gloss as that's what it appeared like it was when I removed it from the car. It was the original TI unit according to the prior owner, since early 1968. Inside the original Delco module was still there. It's Power Transistors were dated before the car build, so it's probable the owner was correct.
                I used the Eastwood gold cad coating on the rear cover, no time to send out one piece for plating.
                Before
                PB040032.jpgPB040033.jpgPB040034.jpgPB040035.jpgPB040036.jpgPB040037.jpgPB040038.jpgPB040039.jpgPB040040.jpg
                After, but before changing the rear cover color. I used the K & B module.
                PC300001.jpgPC300002.jpgPC300006.jpgPC300007.jpgPC300009.jpgPC300012.jpgPC300013.jpgPC300014.jpg
                After recoating the cover.
                Rich
                p.s. I scraped the paint from the case for the ground lug.
                • Robert M.
                  • April 30, 1999
                  • 415
                  Mike
                  http://www.ebay.com/itm/CORVETTE-GTO...ransistor-Ign-
                  AMP/171605949880#ht_1486wt_997
                  Mike
                  How much for yhe above restored amp if I want to keep mine? Mine has new electronics but has over spray from a red car on it.
                  Thanks, Rob
                  • Edward B.
                    • March 29, 2013
                    • 691
                    I too can vouch for Mike's work. I had him restore my distributor and amp and not only did they both turn out like works of art, the car runs great and his prices were extremely reasonable.
                    Ed
                    • Mike Z.
                      • 226
                      Thanks to those that have commented positively about our restoration work.
                      Rob, please send me a private message and I can give you my contact info, or I post my phone number in all of our e-Bay listings under michaelz505: I don't want to step on anyones toes or encroach on any rules and regs of this discussion board.
                      Mike
