Source for telescoping column part? - NCRS Discussion Boards
  • Ronald M.
    • August 31, 1999
    • 44
    I need to replace the turn signal wire cover on my telescoping column (it's barely holding together with electrical tape), but I haven't been able to locate a replacement from any of the typical vendors (several of whom have informed me that its no longer available).
    Who still has these available (and for sale )?
    thanks in advance,
    Ron Myers
    '66 Roadster
    • 43273
    Re: Source for telescoping column part?
    thanks in advance,
    Ron------
    I'm not surprised there are not any around. The part number was GM #7801050 and it was discontinued without supercession in April, 1975. That's almost 40 years ago! So, I'm sure the supply has pretty much dried up by now. Making things worse, this part was used only on 1967-68 Corvettes with telescoping column.
    • Joe R.
      • July 31, 1976
      • 4552
      Ron,
      What is the year of the tele column you are asking about. Can you post a pic of the broken part. I believe the part Joe L. was talking about is for a 67-68 and they are made of metal (I think). The collar around the lower part below the hub is plastic and reproduced and sold by most vendors.
      JR
        • 43273
        Originally posted by Joe Ray (1011)
        Ron,
        JR
        JR------
        Yes, the part I was referring to is a 67-68 item. Somehow, I thought he was talking about a 1967. However, as I look at the bottom of the post, it looks like his car is a 1966. I cannot find any similar part applicable to a 1966.
        • Ronald M.
          • August 31, 1999
          • 44
          It is item number 35 in this shot from the 1966 service manual.
          thanks again,
          Ron Myers
          '66 Roadster
            • 43273
            [ATTACH=CONFIG]56745[/ATTACH]
            thanks again,
            Ron------
            Believe it, or not, I can't come up with a part number for that piece. I believe it used to be reproduced but is no longer.
            • Ronald M.
              • August 31, 1999
              • 44
              thank you Joe, and hence my current dilemma...
              Ron Myers
              '66 Roadster
              • Joe R.
                • July 31, 1976
                • 4552
                Ron,
                I believe that part is a plastic runner for the wiring. It is also used on cars with no tele with a button in the bottom and is held by the bezel and the upper housing. If you could obtain one of the earlier ones from a 64-66 with no tele it can be made to work with your column.
                NCRS Florida meet in Jan. would be a good place to find one. Good luck.
                JR
                • Gary R.
                  • April 1, 1989
                  • 1804
                  I might have some in with the parts I bought when I purchased the stock of steering parts from Corvette Steering. Post a picture. If I recall it is black plastic, heated and wrapped around to form a "duct" for the wires.
                    • 43273
                    Ron,
                    JR
                    JR------
                    I think the 65-66 non-tele wiring cover is currently available in reproduction.
                      • 43273
                      Ron------
                      I strongly suspect that the reason I can't come up with a part number is that this piece was never available in SERVICE. I've gotten several indications to that effect. The part certainly did have a part number but if it was, indeed, never available in SERVICE, then the part number is, for all practical purposes, moot. By definition, there are NO NOS examples of parts never available in SERVICE.
                      • Russ S.
                        • April 30, 1982
                        • 2163
                        Long Island Corvette part number 39-08E
                        • Ronald M.
                          • August 31, 1999
                          • 44
                          Thanks, but if Long Island Corvette actually still had it available, it would be their part number 18-73B.
                          Ron Myers
                          '66 Roadster
                          • Gary R.
                            • April 1, 1989
                            • 1804
                            I believe this is what you are looking for. They come 1/4" longer so the flap can be cut and the hole drilled in it.
                            • Ronald M.
                              • August 31, 1999
                              • 44
                              Yes, that appears to be the correct part.
                              A few others have suggested modifying the non-telescoping part, but to do so would leave the modified part over an inch too short, when compared to an original.
                              thank you again Gary, and referencing my original entry (#1): where can I obtain one?
                              Ron Myers
                              '66 Roadster
