Second design Switzer fan clutches - NCRS Discussion Boards
  • Ken A.
    • July 31, 1986
    • 929
    Joe Lucia or anyone else know the original part #'s used for the other 4 fan clutches used after 67?
    Specifically the 68-70 and the 71-74 parts.
    • 43273
    Re: Second design Switzer fan clutches
    Ken------
    If you're only referring to the Sweitzer-manufactured clutches, here are some of the part numbers:
    GM #3916139-----68-70 small block without A/C
    GM #3937771-----68-70 small block and big block with A/C
    GM #3991426-----71-73 small block and big block, with or without A/C
    The above are the only Corvette fan clutches of Sweitzer manufacture that I know of that were used in the 1968-74 period. It's possible there were others but these are the only ones I know of. I don't think that any Sweitzer clutches were used for the 1974 model year, although the 3991426 may have been used very early in the model year. However, if there was a Sweitzer used, it would likely have been the GM #343720. I am not sure whether it was an Eaton or a Sweitzer.
    • Ken A.
      • July 31, 1986
      • 929
      Joe, you're the best. Did your info come from AIM manuals or service parts books?
      • Ken A.
        • July 31, 1986
        • 929
        Never mind Joe, everything you have said is verified.
          • 43273
          Ken------
          A combination of AIM and P&A catalogs but mostly "other sources".
          Addendum: I should have added, there is NO information in either the AIM's or the P&A catalogs as to whether any particular fan clutch is a Sweitzer, Eaton, or Delco.
