C2 Window Regulator Rivet & Roller Tool - NCRS Discussion Boards
  • Fred M.
    • August 31, 1998
    • 63
    I'm replacing my rivets & rollers on both window regulators but not coming up with any EFFECTIVE methods on my own to properly attach the rivets. Not finding any special tooling listed anywhere either. Anyone have advice on the correct tooling and/or method?
    Thank you
    • 6960
    Re: C2 Window Regulator Rivet & Roller Tool
    Fred, What about placing the roller into regulator and placing on the face surface like the vise, and take a center punch and hit the middle of the rivet to start the peening over of the rivet, then use a couple of small ball peen hammers, place one ball of the hammer on top of the rivet and strike the top of the other hammer to finish the process.(I think the rivets are soft aluminum)??
    • Steve G.
      • November 24, 2014
      • 411
      Hanson Rivets
      Click on tools in the menu bar at the top.
      • Fred M.
        • August 31, 1998
        • 63
        Originally posted by Steve Garner (60691)
        Hanson Rivets
        Thanks for the note, great source of information.
        • Fred M.
          • August 31, 1998
          • 63
          If these rivets were aluminum your suggestion may work but they are mild steel and easily bend over when hit too many times with a hammer.
            • 6960
            Fred, can the plastic rollers be transplanted to the old regulator?? I am not sure if the diameter of the new rivet is the same, I think the plastic roller can be heated with a heat gun slightly to remove. Or maybe take a piece of metal rod and grind out the middle to form a cup and peen the rivet over with a hammer.
            • Fred M.
              • August 31, 1998
              • 63
              Replacement rollers are one-piece, originals are two-pieces. Your suggestion may work if NOS rollers were made available. Rivet size seems to be the same diameter between original and replacements. Thanks
