light bulb filter and hood Asms - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    I am somewhat confused about placement and number of hood assemblies and filters to use on my 66 with A/C light bulbs
    I see on the C-60 section that I should place the bulbs along with the metal hoods and green filters on either side of the clock mount .I assume at the 3 and 9 o'clock position. I also see that the AIM under heater controls , calls out for a light /hood/and filter on the 6 o'clock position of the clock mount as well . I only have two green filters , and as far as I can remember only ever did .
    Does A/C eliminate the 6 o'clock bulb, hood and filter ?
    Lastly ,how many bulbs in total get the hoods, get the filters , and where do they all go ?
    Jim
    Re: light bulb filter and hood Asms
    Jim
    Jim -
    The two added "torpedo" lamps on a separate harness with A/C ("wire assembly") that go at 3 and 9 o'clock are left and right, as noted in the Assembly Manual, so the A/C control bezels get illuminated. The production lamp at the 6 o'clock position is still used, to illuminate the heater control bezels, and its installation is shown in your Assembly Manual in UPC 1-Asm, sheet E6, View "C", items 23, 24, and 25.
    • Jim S.
      • March 1, 1986
      • 1408
      Thanks John,
      I guess that means I am short one green filter !
      Jim
      • Donald S.
        • August 31, 1996
        • 186
        Jim,
        I thought I was missing one as well...look around under / on top of the radio or under the carpet. That's were I found the one I was missing.
        A touch of super glue makes sure they don't fall off again. They are available from most of the Corvette vendors.
        Don
        • Harry S.
          • July 31, 2002
          • 5349
          This extra harness with bulbs, filters and hoods started in 1964. So for you 63 A/C guys, don't start looking for anything.
