TI box on 70 - NCRS Discussion Boards
TI box on 70
  • Michael F.
    • 745
    TI box on 70
    where is the TI box (amp) on a 70 bolted and how many bolts secure it?? Also what, if any, differences between the amps, wiring etc. on the 67-70 boxes. Just so you know, I don't have an AIM yet. Thanks for any help/information you can provide.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
    • 43279
    Re: TI box on 70
    Originally posted by Michael Funk (22104)
    where is the TI box (amp) on a 70 bolted?? I don't have an AIM yet, thanks.
    Michael-------
    It's mounted on the driver side forward inner fender well, to the left of the radiator support.
      • 15632
      Re: TI box on 70
      It is mounted where Joe L says. Three bolts hold it to the inner fender. Some of the earlier (C2) boxes have a connector on the box for the wires. Later (1968 > ) have a short pigtail set of wires leading to the connector. I am not sure where in the C2 era that change took place.
      If you really want to get picky there is a date ont he original boxes, but that is not judgeable on your 1970.
        • 43279
        Re: TI box on 70
        Terry------
        The amplifier with the "on-box" connector was used through 1968. The amplifier with the pigtail connector began for the 1969 model year and was used through 1971. Very late 1968 may have used the amplifier with the pigtail connector.
        • Donald A.
          • January 7, 2013
          • 239
          Re: TI box on 70
          Was the TI some sort of option for some of the engines or was it stock on some? LS-5???
            • 15632
            Re: TI box on 70
            The answer is "Yes"
            For C3s it was a part of the engine option on 435Hp (L71), 1970 & 1971 (but NOT 1972) LT1, and 1971 LS6. It was optional (as K66) in all but base engines in 1968 & 1969. So your LS5 would not have it.
            • Michael F.
              • 745
              Re: TI box on 70
              by "on box" connector, you mean the one that like a big plug boot that slips over the rubber connector on box and the other for 68 on is the one with just wires coming out, right?? thanks
              Michael
                • 43279
                Re: TI box on 70
                Michael------
                The "on-box" connector is, essentially, a female plug mounted right on the amplifier housing. The later style used a pigtail from the amplifier with the female plug on the end of the pigtail.
                • Michael F.
                  • 745
                  Re: TI box on 70
                  Joe which one do you think is better for weather protection? thanks for the great info.
                  Michael
                    • 43279
                    Re: TI box on 70
                    Michael------
                    Probably the pigtail version. In any event, I expect that GM went to the pigtail version for some good reason.
                    • Peter S.
                      • March 28, 2012
                      • 327
                      Re: TI box on 70
                      Hi Michael,
                      Here is a picture of the driver's side wheel well on a '69 where you can see the three bolts popping through that hold the amplifier in place. I do believe the location, which is not exact at the factory, is the same for 1970.
                      And a snapshot of the AIM:
                      • Michael F.
                        • 745
                        Re: TI box on 70
                        thanks guys, very helpful information
                        Michael
                          • 3418
                          Re: TI box on 70
                          Hi Peter and Michael,
                          Peter's picture made me take a look at my 71.
                          I see 2 distinct dimples (positioned it appears for the 2 lower fasteners) on the forward side of the apron. Nothing is visible from the wheel side of the apron.
                          They are however positioned on the other side of the headlight header support bracket than those shown in your picture Peter. I'd describe them as between the little 2 bolt bracket for the header and the core support.
                          So it seems the dimples carried on after 70.
                          • Graeme B.
                            • October 23, 2007
                            • 213
                            Re: TI box on 70
                            On my '69 L71 they were the same as in Peters photo. My dimples were still there untouched but I guess the assembly line workers just put them
                            where it was easier to install.
                            • Peter S.
                              • March 28, 2012
                              • 327
                              Re: TI box on 70
                              Hi Alan,
                              That's a tough area to describe, but I think even tougher to get a picture of. I think I've captured it (albeit w/ a grainy cell phone picture).
                              The dimples are approximately 4" apart, whereas the bottom two bolts on my amplifier are 2 3/4" apart. I don't think those dimples were for the amplifier.
                              EDIT: The top bolt and bottom right bolt (in my first picture of the wheel well) are 4" apart. Perhaps it is a matter of the orientation? How were they mounted/oriented on '68s with the plug that Joe described?
