67 wiring harness clips SB vs BB - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1588
    On the drivers side inner fender with the 4 plastic clips. One by the hood support(BB), two close to the alternator and the forth by the voltage regulator. Are the two by the alternator the same on a SB as BB seeing how the alternator is in a different location. The car had the front clip replaced so I am trying to get all the correct locations. We also have a un-hit 67 SB car to compare. This is for a 427 car
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 67 wiring harness clips SB vs BB
    Keith,
    The black plastic retainers used on the inner fenders are the same on SB and BB. They do have the ability to hold more wires as there are two holes in each retainer.
    JR
    • Keith B.
      • 1588
      Joe I realize the plastic clips are the same. Are they in the same location
      • Leif A.
        • August 31, 1997
        • 3643
        Keith,
        Yes, they are. Page 153 of the '67 TIM&JG states "The left headlight harness lead has a tan wire connected to the bottom of the brake differential pressure switch and is routed over the top of the left inner fender skirt and held in place with three push-in wire ties...etc, etc" No call out for differentiation between SB and BB.
        Leif
