Is there any info out there that is specific to the hard tops for the c2 cars? I have a June car and would like to learn what a correct top might be. thanks
63 hard tops
Re: 63 hard tops
Isn't this in the Judging Manual???? If you don't have one get one.
The Auxiliary Hardtop for 1963-1964 models had three distinct designs.
Design One: At the startup of 1963 production the auxiliary hardtop had a notch cut in the bottom, each side, to give greater clearance above the door. This design was present until approximately March 1963.
Design Two: For cars built in approximately April, May and June 1963 the notch in the auxiliary hardtop is not present.
Design three: For cars built approximately near the end of June 1963 until the end of 1963 production and all 1964 production the notch in the auxiliary hardtop is not present and rear window reinforcing brackets are present at the upper center and lower center of the rear Plexiglas.
- Top
