Is this an original 73 smog belt? - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5153
    Part number agrees with AIM as the water pump to smog pump pulley belt. It was with some late 72-early 73 smog parts I picked up. Pump is mid-September 72. Hoses are ink-stamped correct for 70-72 72 and 73 small block.
    Does this look like the factory-installed belt? By the way, the tower clamps are dated 2/72, 2/71, 2/72, and 3/72.
    • 43290
    Re: Is this an original 73 smog belt?
    What do you think about the belt?[ATTACH=CONFIG]56635[/ATTACH][ATTACH=CONFIG]56636[/ATTACH]
    Mike------
    I think it's original. Later GM SERVICE belts of this part number had printed script rather than embossed.
      • 11698
      I think the belt is very nice! I would also suspect it is original.
      And if you don't have any use for those tower clamps...
      • Russ S.
        • April 30, 1982
        • 2163
        It is the original belt. It matches the original belt removed from one of my 73s by me and saved when the car was nearly new. 73 L82 auto w/air. I would expect it was used on other 73 applications as well.
        • Harmon C.
          • August 31, 1994
          • 3228
          I agree this is an original 73 smog belt.
          Lyle
