Hi Folks, trying to get at the speakers on my 69. One speaker does not work and as I look up under the passenger side I see some wire piggy backed on the green/black speaker wire. Whatever for? That speaker works however. But I know I need to remove the plastic piece with the louvers for the vent. Do I need to pull the dash piece down so I can work the plastic piece out? I did remove the add on wire and tape up where it was stripped back. This is an original low milege car that you would never guess someone jerked with the radio, but that never fails does it? Thanks, Ray
