NOS 59-61 Oil Cap - NCRS Discussion Boards
NOS 59-61 Oil Cap
  • Bob B.
    • March 1, 2003
    • 831
    NOS 59-61 Oil Cap
    Hi all,
    I have an NOS 1959-61 oil cap, but the problem is that it is spotted. I'm wondering if there is any non-destructive way to remove these spots?
    Bob
    • 43221
    Re: NOS 59-61 Oil Cap
    Originally posted by Bob Baird (39424)
    Hi all,
    Bob
    Bob-------
    Those spots are a form of corrosion. You can remove them chemically but they'll probably return unless you seal the cap with some sort of clear coating or paint. Evap-O-Rust might clean the corrosion without otherwise changing the natural finish.
    • Jimmy G.
      • November 1, 1979
      • 976
      Try "Rub - N - Buff" Available from Michaels or most other craft stores. You will be surprised at what it can do
        • 6942
        Bob, the plating appears to be missing, Likely moisture. I not sure that polishing will help, I think a very light coating of dull silver spray paint may help, Most of the hardware stores or Home depot, Lowes may have.
        • George W.
          • July 31, 1998
          • 322
          Bob,
          That appears to be an original non FI cap; follow Jimmy's suggestion...I would not paint it, clean it and go with it.
          Dr. George
