On a 65 4spd car rear tranny mount uses two big thick washers anyone know the diameter on these and thickness, thanks
C2 Rear tranny mount big thick washer?
Re: C2 Rear tranny mount big thick washer?
If so, the two used ones that I have that came (loose) with a rear mount are 0.15" thick, 1.00" OD, and 0.46" ID. The bolt is 0.425" by 1.40" OL with an "M" head marking with 3 radial lines (if that helps to identify).- Top
Jim------
These are the GM #3700338 that Wayne mentioned. The spec I have on them is an ID= 0.46", OD= 1.38", and thickness= 0.18"
Reproductions are available from AMK Products.In Appreciation of John Hinckley- Top
