1956 Corvette Engine Upgrade - NCRS Discussion Boards
  • Donald D.
    • 5
    II am looking to upgrading my 56' to one of the newer ZZX crate engines and preserve my original motor. Has anyone any experience with the 350-Ram Jet, the ZZ3-383, ZZ4-350 or ZZ5 350s? I was concerned about hood clearance and any other issues that anyone might have come across that I should be considering. Thanks for your replies.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 1956 Corvette Engine Upgrade
    I put a Ramjet 350 in a 62 Corvette years ago.
    Only issue's were hood and harmonic balancer clearance which were easily resolved.
    Great engine.
    • Terry D.
      • May 31, 1987
      • 2697
      Hopefully Tom Parsons will chime in, I believe he put a big small block in a 56
      • Stuart F.
        • August 31, 1996
        • 4676
        As I recall, Tom took pains to make the new engine appear close to the original with some additional enhancements. It was a great swap.
        Stu Fox
        • John F.
          • March 23, 2008
          • 2419
          Don't forget the heavy duty "U" joints as well. Twisted the drive shaft back in 68 w/ a crate motor.
          • Joe R.
            • May 31, 2006
            • 1822
            Terry,
            Yes, I'm pretty sure he put a 400 cubic inch small block in his 56, with a Rochester FI unit he modified for more airflow with the bigger engine. I think he also did some PCV plumbing in the lifter valley.
            Joe
            • Donald D.
              • 5
              Thanks to all that responded to my request. have a Merry Christmas and a Happy New Year!!!!!
              • Donald D.
                • 5
                Do you mind sharing any more that you had to do with your 62'. Thanks, Don
                • Tom B.
                  • March 1, 1978
                  • 726
                  If you want the Rochester look in a modern Fuel Injection you might consider this.
                  Arizona Speed and Marine
                  • Donald D.
                    • 5
                    Thanks for the lead.
