Gas Pedal / Accelerator lever - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    Did I reverse my lever , and or is it supposed to make a bend outward rather than inward ?
    I hope I don't have to reverse it , but it does make contact with the ignition shield brace.
    See Photo attached ,
    Jim
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Gas Pedal / Accelerator lever
    Appears to me to be correct. You may need to bend the accelerator lever toward the distributor a little or lengthen the card rod.
    • Jim S.
      • March 1, 1986
      • 1408
      Thanks Russ.
      So you're telling me that there was something I had a 50/50 chance at , and I got it
      right !!!! Are you Sure ???
      Jim
      • Russ S.
        • April 30, 1982
        • 2163
        It is a curved lever. It can't be reversed. If it could be it would curve downward into the intake manifold.
        • Jim S.
          • March 13, 2013
          • 360
          Isn't your ground strap mounted on the wrong side of the lever? I believe the bolt inserts from the outboard side.
          • Michael G.
            • January 1, 1997
            • 1251
            Your answer is in the factory assembly manual........same for ground strap.
            • Jim S.
              • March 1, 1986
              • 1408
              Jim,
              Thanks, Yes it is .
              Like I said, whenever there is a choice ! My perfect record stands ! Luckily that one is an easy fix !
              Jim
              • Jim S.
                • March 1, 1986
                • 1408
                Russ and Michael,
                Just for clarification, and in the way of proof that I do in fact consult the AIM before I post questions. I offer this up for your perusal. . Sometimes it’s a huge help, sometimes it a cause of confusion. At least to me !
                Case and point . The bottom of the accelerator lever has a flush side and a folded over or boxed side . . (see photo ) In the AIM - UPC 6 – D1 it appeared to me to show the flush side mounted to the swivel/support assembly , and the boxed/folded over side, on the outside . So that is how I attached it , and as Russ confirmed, I got it right .
                However , as Russ pointed out in his response “It is a curved lever. It can't be reversed.. If it could be it would curve downward into the intake manifold.” . Well I may not have thought it all the way through, however I did realize it would make it point in that direction. Coincidentally , that’s sort of the way it is pictured in the AIM on UPC-6-D2 and D3, and not at all how it looks on my car . (see photo 2)..Further if you notice the arched cut out half way up the lever , on mine it is on the rear of the lever , while the picture on page D3 clearly shows it in the front .
                So (A. ) since my lever was rubbing on the ignition shield brace ,(B.) seemed to be pointing the wrong way ,(C.) me being a novice at this , and (D.) given the chance, often getting it wrong , I decided to ask the experts which way was correct.
                As always glad you guys are out there .
                Jim
                • Leif A.
                  • August 31, 1997
                  • 3653
                  Jim,
                  Your car is coming along beautifully. What an immaculate job you're doing. I go thru the same issues with the AIM, service manual & shop manual. If I think there may be more than one way to do something after reading all that, I always ask the question here on the forum. I'm numb to the few snide remarks that come back because I know I will always get a straight answer from most here on the forum. By the way, did you restore your carb yourself? Again, beautiful work.
                  Leif
                  • Jim S.
                    • March 1, 1986
                    • 1408
                    Originally posted by Leif Anderson (29632)
                    Jim,
                    Thanks Leif ,
                    I'm trying to make it the best car I can.
                    The Carb was restored by Jerry Luck awhile back. He was recommended by quite a few on this forum. He wasn't cheap or quick, but he did a great job.
                    Jim
