63 power brake Master cylinder - NCRS Discussion Boards
  • Gary P.
    • May 31, 2005
    • 104
    Is there a difference in a 63 corvette power brake master cylinder, than a non corvette one, like the impala. This lid also has the larger lettering on top, as the original corvette are small. Need a little help. Thanks.
    • 6956
    Re: 63 power brake Master cylinder
    Gary, the 63 Corvette master cylinder is a 7/8" bore some of the other pass car 63 master cylinders are 1" bore, they work on different pressures because of this. Don't use these on a corvette. All lettering on original 63 master cylinders had a 1/8 inch lettering, the reproduction ones a 1/4" letters.
    • Gary P.
      • May 31, 2005
      • 104
      This master cylinder has the 7/8 on top front. It has the larger 1/4 letters for the lid. Maybe the cylinder is original and the top a reproduction
      • Harry S.
        • July 31, 2002
        • 5344
        What is on the bottom, should be a casting number, mold number and a date.
          • 6956
          Gary, To add to Harrys post check to make sure the line to master cylinder is on the same side(facing wheel well). its possible its a corvette master what your looking at and not a pass. car.
            • 43277
            Gary------
            The same master cylinder as used for 1963 Corvettes was also used for 1963 passenger cars with power brakes and metallic linings.
            • Gary P.
              • May 31, 2005
              • 104
              number on bottom 5462389 under that R1 and date is C-25-3 also the brake line is on the driver side.
              • Harry S.
                • July 31, 2002
                • 5344
                Gary, from what you indicated it looks like a real one. Look at the date closer, it's probably C 26 3 as I do not believe they made a batch on C 25 3.
                • Gary P.
                  • May 31, 2005
                  • 104
                  The date is very hard to read. will check . Thanks, Gary
                  • Gary P.
                    • May 31, 2005
                    • 104
                    The numbers are very hard to read, so I had an expert look at it. ( WIFE ) she came up with C-26-3
