C2 seat tracks and headlamp motors - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2016
    Is there a non-distructive way of taking a seat track apart? I want to glass bead the parts without getting glass bead in the balls or rollers that slide between the pieces.
    I know I have seen an article about rebuilding headlamp motors in an old Restorer. Does anyone remember when that article was published?
  • Don H.
    Moderator
    • June 16, 2009
    • 2283
    Re: C2 seat tracks and headlamp motors
    HL motor restoration in Vol 39, Number 1, Summer 2012. Page 36-48.
    sorry, no help on the seat tracks.
    • Patrick B.
      • August 31, 1985
      • 2016
      Thanks Don, I found it.
      • Russ S.
        • April 30, 1982
        • 2163
        I have had seat tracks apart. It was fairly easy but I don't recall the details. If I remember right you need to open the seat lock/ adjustment lever farther than normal to disengage it.
        • Patrick B.
          • August 31, 1985
          • 2016
          I'll give that a try. What about the other seat track without the seat lock lever?
          • Russ S.
            • April 30, 1982
            • 2163
            They both have seat lock levers.(to slide the seat back and forth)
            • Ed S.
              • August 6, 2014
              • 1390
              Patrick
              When I stumble across a "how to" article pertaining to a '64 or C2 Vette I save it to a file for future reference. I have two such files relating to C2 headlights, one on motor repair the other on "bucket" repair. Not sure if either of these is the one you have in mind - hope it helps.
              Ed
              • Patrick B.
                • August 31, 1985
                • 2016
                Originally posted by Ed Szeliga (60294)
                Patrick
                Thanks Ed, the motor rebuild article is very helpful.
                • Neil L.
                  • February 1, 1997
                  • 44
                  Patrick,
                  Corvette America has a video showing the removal of the seat tracks. Go to this link and watch video 1. The seat track removal is near the end of the video.
                  http://www.corvetteamerica.com/video/65_67scInstall/
                  • Patrick B.
                    • August 31, 1985
                    • 2016
                    Originally posted by Neil Levine (28723)
                    Patrick,
                    Thanks Neil --- That video covered the seat track disassambly nicely for a 65 seat. But, I just learned something unexpected from this video. The seat tracks for a 67 are entirely different from 65 seat tracks. They are not even similar. Maybe Russ's suggestion also applies only to the earlier C2 seat tracks and not 67.
                    • Russ S.
                      • April 30, 1982
                      • 2163
                      Pat, I was referring to 66. Didn't realize 67 was different.
                      • Patrick B.
                        • August 31, 1985
                        • 2016
                        Russ-- I'm not sure what a 66 uses but a 67 is way different from a 65. 67 seat tracks resemble heavy duty drawer slides with rollers or balls between the stationary and moving beams, each having rectangular cross sections. .
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11366
                          1967 seat tracks are unique. I rebuilt a few. IIRC, here's how.
                          At each track end there's a dimple. Take a drift and a BFH and flatten the dimple(s). I don't remember if there are 2 or not. I think 2.
                          Remove the old worn/broken plastic slides and replace every one with this kit......
                          The page you were looking for was not found or has been deleted. Search Corvette Parts by year or category instead.
                          If needed, replace the rollers or other worn parts.
                          When done, use your drift and BFH to re-create the dimples.
                          Rich
                          • Patrick B.
                            • August 31, 1985
                            • 2016
                            Thanks Rich -- That's what I needed to know. Destructive but reversible in theory.
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11366
                              I just found this in my files......Here's where I got the info when I did it before. It came with the kit. Also attached for future reference.....Rich
                              https://www.paragoncorvette.com/corv...ions/4962K.pdf
                              4962K.pdf
