I am looking at the C60 AIM page that changes the battery cable position for A/C , but the picture is vague and the wording faded. (it says "clutch ??? attaching bolt ", I assume it means the bell housing bolt immediately behind the oil filter. I am further assuming that the cable goes under the Clutch Rod but over the Clutch Fork Rod and spring .Correct ???
Also if the Single Black Ground wire that went to the attaching bolt of the Starter along with the battery cable on non A/C cars still goes there even though the battery cable does not .
Jim
Jim
