63 Convertible Top Welt Binding - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 305
    The 67 judging manual has very specific info with respect to the length of the binding downward from the seam where it terminates with the stainless steel spear-shaped tips.
    The current 63 manual does not cover these specifics. Are the 63's & 67's the same ? I know the 63 spear does not have the flat narrow flange on its tips.
    Also is the front welt fold under the same 63 vs 67?
    Steve Gansky
    Newtown, (Bucks County) PA
    • 6956
    Re: 63 Convertible Top Welt Binding
    Steve, I just went through a regional event and did not notice the judges taking a measuring tape and checking the length although I installed the top on my 63 there was a measurement on the instructions, I did have one very small issue the judges picked up on it involves the front sealing strip not being quite long enough to wrap under the corners of the front, Al Knoch strips are about a 1/2 in. to short on each end. the sealing strip should have the small dia. for 63 , also should have the front bow sitting in the middle of the sealing strip.
    • Stephen G.
      • January 1, 2002
      • 305
      Ed
      Thanks for the input. I had already ordered the additional charge "correct" front welt for my 63 and today just ordered (yet another $40) a corrected correct front welt 2" longer. That way my top guy has plenty of material to work with and can resew as needed.
      Steve
      Steve Gansky
      • Harry S.
        • July 31, 2002
        • 5344
        Here are the pictures I took of the 1963 Z06 Convertible. This is the original top.
        Notice the tucking of the windlace. Also, This is a tan top with a tan interior.
        Good Luck......
        • Stephen G.
          • January 1, 2002
          • 305
          Harry
          Anything showing the length of the rear welt before it terminates into the metal spear ? Any other pictures. Some of the resolution is poor.
          Steve
          Steve Gansky
          • Harry S.
            • July 31, 2002
            • 5344
            Steve, I just looked at your profile... Your in PA. The owner of the car is close to you. He is the owner of Tony's Corvette Shop in MD.
            Give him a call and he may invite you to take some pictures or send you some.
            I posted all I have.
            • Stephen G.
              • January 1, 2002
              • 305
              Thanks. I'll give them a call.
              Steve
              Steve Gansky
