Identify Correct 72 Alternator Fan?? - NCRS Discussion Boards
  • Norm C.
    • April 1, 1989
    • 227
    I have received a correct dated alternator, but not sure if its the correct fan. Could not locate in archives an "Alternator Fan ID" discussion,,,,, could any of the judges help describe the fan blades and if there are any stamps or other features of the correct fan?
    As always.... thanks in advance for any assistance!!!
    • 43279
    Re: Identify Correct 72 Alternator Fan??
    Norm-------
    While there are slight differences in the 2 fans shown in the attached photo, I believe that both are GM #1966990 and I believe this is the fan used for 1972.
    • Norm C.
      • April 1, 1989
      • 227
      Thanks Joe!!!! Just couldn't ask for anything better than that!!
      • David L.
        • July 31, 1980
        • 3310
        Joe,
        I believe that that the fans in your photo are not the same number. Apparently in my photo below the LABELS ON MY TWO FANS SHOULD BE SWITCHED. I believe that one of the fans in my photo below is GM # 1969448 as referenced in the Sept. 13, 1968, Technical Service Bulletin. I guess the fan on the right side in my photo with the "shark fin" is actually GM 1966990 as it is the same as your NOS 1966990.
        Dave
          • 43279
          Dave-----
          The GM #1966990 is from the box beneath it. So, I'm sure it is a 1966990. The other fan in my photo is the original fan from my 1969 GM #1100859 alternator. That alternator was manufactured in August, 1969. The GM #1969448 was discontinued from SERVICE in May, 1969 and I expect it was dropped from PRODUCTION use well prior to that time. It was replaced by the 1966990 and I expect that's what was used on my alternator and pictured.
          The "notch" in the blade, which you also point out in your photo, is the only real difference between the two fan blades I pictured. My original fan has only a very slight "notch" and the NOS 1966990 has a more pronounced notch. However, this could have been a change to the drawing for 1966990.
          • David L.
            • July 31, 1980
            • 3310
            Joe,
            I sure would like to see a NOS 1969448 fan.
            Dave
              • 43279
              Originally posted by David Liukkonen (3775)
              Joe,
              Dave
              Dave------
              Unfortunately, I do not have an NOS example of the 1969448. Its having been discontinued so long ago, finding one would be difficult. Since GM rarely included a stamped part number on alternator fans, positively identifying a used piece is impossible.
              I expect the use of the 1969448 in PRODUCTION probably ended about the date of the service bulletin you posted a copy of.
              • David L.
                • July 31, 1980
                • 3310
                Joe,
                The 1969 Camaro Parts Catalogue (Nov. 1968) lists the following:
                2.274 Fan, Delcotron
                1966990 1968-69 ALL 37 or 42 AMP
                1969448 1968-69 ALL 63 AMP
                Do you have any idea why?
                Dave
                • David L.
                  • July 31, 1980
                  • 3310
                  Joe,
                  Have you ever seen an alternator fan like the one in the photo below?
                  Dave
                    • 43279
                    Joe,
                    Dave
                    Dave-------
                    I think this is one of those "questionable" references in the P&A catalogs. I think the 63 amp alternator of the late 60's was used in few, if any, passenger cars. I believe it was a different series alternator than was generally used in passenger cars (i.e. it was not a "DN" or "SI" series). In any event, I'm virtually certain that the 63 amp unit was never used in Corvettes.
                      • 43279
                      Joe,
                      Dave
                      Dave------
                      I don't think the black paint is original but I believe the fan is a GM #800594. This fan ultimately replaced most of the other alternator fans.
                      • David L.
                        • July 31, 1980
                        • 3310
                        Dave------
                        Joe,
                        Enclosed is a photo of a NOS 800594 fan that I bought at my local Chevrolet dealer.
                        Dave
                        • David L.
                          • July 31, 1980
                          • 3310
                          Dave-------
                          Joe,
                          I assume 1968 Chevrolets w/AC (maybe only in Canada) used a 63 AMP alternator as referenced in the Sept. 1968 Technical Service Bulletin concerning the noise problem with 1968 passenger cars equipped with V8 and Delcotron high speed fan (GM # 1969448). According to my research the 1968 Corvettes with AC used a 61 AMP alternator, 1100750. According to the 1968 Camaro AIM V8 models w/AC used a 1100796 alternator, 61 AMP.
                          Dave
                          Dave
