C2 Rear fenders - NCRS Discussion Boards
C2 Rear fenders
  • Ralph P.
    • February 1, 1990
    • 253
    C2 Rear fenders
    I have a buddy restoring a '63 coupe. The body is all original glass in excellent condition except the inside rear fender "lips" have been cut away for big tire clearance. It seems a shame to cut up that original glass just to piece in after-market sections containing these lips.... Looks like one could use some resin & glass to form new lips without touching the outer fender.... Anyone done this with success?? How?? THANKS
  • Bill W.
    • March 1, 1980
    • 2000
    Re: C2 Rear fenders
    Yes you can make lips .It takes time . You can make your own mold off the car and get it close to the correct shape then bond it on and finish it off OR buy a repair section from Sermersheims (812 424 4701) and use just the part you need and finish it off on the inside and outside . If you are careful you might only need to paint the lip area or do a blend .
    • Russ S.
      • April 30, 1982
      • 2162
      Re: C2 Rear fenders
      Done it with great success. Just be sure to taper all adjoining edges and feather or blend into the panel on both sides.
      • Ralph P.
        • February 1, 1990
        • 253
        Re: C2 Rear fenders
        Thanks, Russ & Bill !
