correct S/B 69 base model fan clutch - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: correct S/B 69 base model fan clutch
    I have the original fan clutch for my Oct. '68 small block (300 hp), A/C car. It is the Schwitzer model. If the ice on the roads melts later today I will go to the shop and take a picture and post it.
    Jeff
    • Roger D.
      • June 3, 2014
      • 180
      Jeff that would be interesting to see even though I have no AC, thank you
        • 43221
        #18
        Originally posted by Roger Dinunzio (60097)
        I hate to beat a dead horse but is this what I am looking for. 5 15 68 but I don't see Schwitzer anywhere. I cannot load a picture for some reason. I can email someone for opinion or go to the forum to my rvzio 69 restore post. Thank you
        Roger------
        The Schwitzer brand name will not be found anywhere on the clutch. The abbreviation "SC" will be seen stamped on the flange with the date. The "bi-metallic" rectangular plate thermostat also identifies it as a Schwitzer-style clutch.
        By the way, America's Finest Corvettes reproduces the Scwitzer-style clutches for both big block and small block applications. They will date them however you wish. These reproduction clutches look very good. How they perform, though, I do not know.
        • Roger D.
          • June 3, 2014
          • 180
          #19
          Thanks Joe, I should have known that. Were you able to look at my post on the other forum. I have a picture that I would like to know is correct.
          Thanks.
            • 43221
            #20
            Thanks.
            Roger-------
            I do not visit the other forum.
            • Roger D.
              • June 3, 2014
              • 180
              #21
              Joe, I am going to go with what you mentioned if NCRS is okay with that for judging. They carry a warranty and the setup would carry the correct date that they stamp and is a whole lot cheaper then what guys are asking and they all nee to be rebuilt. Thanks
              R
              • Jeffrey S.
                • May 31, 1988
                • 1882
                #22
                Here are the photos of a base engine fan clutch. This was restored several years ago.
                Jeff
                  • 43221
                  #23
                  Jeff
                  Jeff-------
                  This is a GM #3937771. It was used for 1969 small blocks with A/C. However, I don't think it was used for 1969 base engine small blocks without A/C.
                  • Jeffrey S.
                    • May 31, 1988
                    • 1882
                    #24
                    Joe,
                    Yes, the car is A/C.
                    Jeff
                    • Roger D.
                      • June 3, 2014
                      • 180
                      #25
                      I do have available to me an original clutch dated 5 15 68 from a big block. I would think that this might work since it was not exclusively used for just big blocks. Joe is that right?
                      • Roger D.
                        • June 3, 2014
                        • 180
                        #26
                        This one is available to me with the date of 5 15 68 for a big block which I guess could work since they were not exclusive to just big blocks. 009.jpg010.jpg007.jpg
