67 BB Radiator Overflow Hose - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 304
    My replacement shroud did not have the holes for the straps that hold the overflow hose to the shroud. I need the location of these holes and the orientation of the straps. A picture would also be helpful.
    This is a 400 HP air car.
    Steve Gansky
    Newtown, (Bucks County) PA
  • Douglas L.
    • August 31, 2003
    • 302
    Re: 67 BB Radiator Overflow Hose
    The top hole is 3/4" down and 3/4" in to center. The bottom hole is 8-1/2" down to 3/4" in to center. The hole size is a "tight" 1/4" - maybe 15/64's.
    • Stephen G.
      • January 1, 2002
      • 304
      Thanks Doug. Just what I needed!. It looks like you have an unrestored original car - from what I can see from the photos. Mine is as well. I did have to replace the radiator and discovered that when the radiator was pulled to be repaired in the 70's they screwed up the shroud big time. So I replaced the shroud and radiator at the same time.
      My question is if your shroud is original do you think it was painted? There seems to be a lot of conjecture about this. I left my unpainted just like the one I pulled out. I don't understand why they would waste time & money painting a component in the engine compartment that looks great as unpainted fiberglass when the didn't even bother putting paint on unseen areas of the exterior body.
      Thanks for the help.
      Steve
      Steve Gansky
      • Mike M.
        • May 31, 1974
        • 8400
        all three of my 67 bbc shrouds were bare fiberglass. mike
